Hi everyone.
I know this may sound a bit basic.
How can you print pdf using DWG Editor with all lines to print in black.
what happens is that when rint to pdf all line colors stays the same. i need all lines to black.
TIA.
TIA.
Try this....when you go to print click on the "Advanced" tab. Under the Print Style Table select monochrome. That should take care of it. I hope this helps!
