0 Replies Latest reply on Jan 16, 2008 6:06 PM by Jason Zimmerman
    Problem inserting pictures into drawings
    Jason Zimmerman
      I think this is a bug, but thought I would post for any suggestions or comments on a way around it, or if others are seeing the same problem.
      I have a drawing with three sheets with a different single jpg. inserted onto each sheet with a few notes pointing to different things. When I print, all sheets have the picture that was on the first page, not the desired picture. The correct notes are still there. That means sheet 1 is correct, the remaining are not. Same happens with PDF's and image writer.
      Second issue, publishing to an edrawing does not display the pictures at all.
