When exporting as a DWG/DXF, select the Options button in the
lower right and set up your export options. In that screen you can
set up a file that will map the entities in SoldWorks to the
appropriate entity in AutoCAD.
I suspect there is something in the SW Help that talks about this.
Cheers,
