Here is a basic question:
How do you set up PDMWorks so that it does NOT increment the revision on a file every time you check it in? I want to set it up so the user has to manually increment the revision for doing something legitimate, like changing a feature, instead of simply checking in and out.
Joel
Joel
Normally working copy is set in the admin tool as +
When you checkin, select the revision with the + then everytime you checkin it will overwrite the previous version automatically until you chenage the revision to something else.
