I'm working on a rather complicated assembly with a lot of
features defined in context of other parts, including a couple of
weldments. In order to produce 2D drawings for these weldments,
i've used the save bodies command to save the individual weldment
pieces in their own part files to be imported into the drawings.
I've also utilized the as welded/as machined derived configurations
on each of these parts. Long story short, I've got a lot of files
that are VERY interdependant on one another.
Every once in a while when I rebuild the assembly, the program will get stuck in a loop where it repeatedly rebuilds the same features over and over. I've seen it eventually work to a solution after several minutes before, but most of the time this goes on for longer than I have the patience for and I have to kill the program in task manager.
I'm wondering 1) is this a common issue? If so, 2) what are some good practices to use to avoid this situation besides avoiding in-context parts?
In my experience, the number one cause of the "Rebuild Loop" is "Circular External References".
RE:"I'm wondering 1) is this a common issue? If so, 2) what are some good practices to use to avoid this situation besides avoiding in-context parts?"
You seem to already know the answer yourself. So, go back and double check all your External References, tedious I know.
Good Luck.
Maybe someone else has another suggestion.
