Hello all,
I work for a high mix fab shop and my team and I are wondering if anyone has any tips for getting the most out of bend deduction tables in Solidworks. We are looking to try to use this functionality for developing flats for a panel bender. We are familiar with sheet metal, bend calcs, etc so setting up the table wouldn't be the issue but we want to integrate these things into SolidWorks and make it as seamless to use as possible.
That being said, is it possible to set up one single bend table to takes into consideration things like material or even bend length? In other words, what are the capabilities and limitations of bend tables? And are they the best way to develop flat patterns with a lot of variation in material type, thickness, and bend radius?
Thanks in advance,
Evan
Evan,
Now I understand; you have a bend radius that is a function of length (or weight). I think your only option to get accurate flat patterns is to have some data that relates bend radius to length/weight and then use those radii in SolidWorks. (Once the bend radius reaches about 3+ times the material thickness the k-factor is very close to .5 so it could remain constant, however, that is a rule-of-thumb and should be verified.)
I've never used a panel bender, just press brakes. Our brakes always gave us coined 90 degree bends or air bends for bends less than 90, but we always had repeatable results so it was not that much work to develop the necessary data.
Unless the manufacturer of the panel bender can help you I think your only option is to get as much data as possible and develop your correlations. Even after you do this and start making parts from it I recommend you continue to measure the bend radius and the resulting flange lengths to see how they compare to your "predicted" values. You can then use this to further tweak your values.
