I have an animation of an assembly..
The assembly has been revised with a few new parts in it..
I added a new Explode step for the new parts.
But i can't figure out how to get the new explode step into the existing animation.
How do i get the existing animation to utilize the new explode step?
In SWX 2007
One way to do this is to create a new animation tab > use the wizard and create your exploded animation. Select and copy the new key points. Now go back to your primary animation if need be you can select your timeline key points and move them. Paste the exploded key points in your existing animation. Once you are finished, delete the new animation tab you created.
Vince
