Andrew Terry
Customer Toolbox Macro
Discussion created by Andrew Terry on Dec 27, 2007
Latest reply on Dec 27, 2007 by Anna Wood
I discovered that SW2007 SP5 does not use the toolbox.ini file. I have also read that 2008 will no longer use the ini file but a setting in options.
This is a problem for us. We have different customers with different toolboxes. We used different start icons with batch files to change the ini file to the correct directory. Since the ini file is no longer used, we have to manually change the setting in options.
My question: are there any known macros that change this setting? Is it possible to have a macro that changes this setting?
I am not a vb programmer. The macro record did nothing for me. If there is one available I can probably edit it to suit my needs.
