Dear All,
Is it possible to take dimension or create 2d drgs from .eprt files (e-drgs)?
Also is it possible to assign material and find the weight of the part which is in .eprt format, if the part is not assigned any material in .sldprt format (solid model)?
Regards
Regards
If the eprt was created with SW Professional or above, it can be saved with the option to measure.
Basic SW can't enable "Measure" and the measure tools will be greyed in the eDrawing viewer.
There was a bug in SW2007 Pro that only allowed the Measure to work if you used the Save As eprt and you set the Options.
You couldn't use "Publish eDrawings File" and then enable Measure.
It would not turn on Measure in the saved file.
I don't know if this was fixed.
