The 43.95 dimension extension endpoint below doesn't change correctly when moving the dimension from the right side to left side. Notice how the 19.91 dimension is correctly displayed on right side or left.
It works as expected during the creation of a new sketch. It stops working correctly after the sketch is used to make a revolved feature. I believe this issue started happening on SW2015.
Any Ideas how to fix? This adds a lot of extra work on drawings to manually change the gap.
It depends on what you're selecting to create the dimensions. Check video for explanation.
