5 Replies Latest reply on Jun 6, 2016 7:21 AM by Mario Zahren
    How to delete File from Vault?
    Mario Zahren
      Hello all,
      im trying to create an AddIn for EPDM to delete preselected Files in a Folder. I´m using the code from a sample AddIn which shows a messagebox where the selected files are shown with ID and Filename.
      Here the code:
      using System;
      using System.Collections.Generic;
      using System.Linq;
      using System.Text;
      using System.Threading.Tasks;
      using EdmLib;
      using Microsoft.VisualBasic;
      namespace EpdmAddInFunktionen
          public class Class1 : IEdmAddIn5
              public void GetAddInInfo(ref EdmAddInInfo poInfo, IEdmVault5 poVault, IEdmCmdMgr5 poCmdMgr)
                  //Specify information to display in the add-in's Properties dialog box
                  poInfo.mbsAddInName = "AddInName";
                  poInfo.mbsCompany = "CompanyName";
                  poInfo.mbsDescription = "Delete " + Constants.vbLf + "Add " + Constants.vbLf + "Change " + Constants.vbLf + "etc. ";
                  poInfo.mlAddInVersion = 1;
                  //Specify the minimum required version of SolidWorks Enterprise PDM
                  poInfo.mlRequiredVersionMajor = 5;
                  poInfo.mlRequiredVersionMinor = 2;
                  //Register menu commands; SolidWorks Enterprise PDM passes command IDs, 1000 and 1001,
                  //to IEdmAddIn5::OnCmd to indicate which command the user selects
                  poCmdMgr.AddCmd(1000, "Delete", (int)EdmMenuFlags.EdmMenu_Nothing, "Delete File", "Delete", 0, 99);
                  poCmdMgr.AddCmd(1001, "Add", (int)EdmMenuFlags.EdmMenu_MustHaveSelection, "Add File", "Add", 1, 99);
              public void OnCmd(ref EdmCmd poCmd, ref Array ppoData)
                  IEdmVault5 vault = new EdmVault5() as IEdmVault5;
                  vault.Login("admin", "xxx", "VaultName");
                  //Handle the menu command
                      string CommandName = null;
                      if (poCmd.mlCmdID == 1000)
                          CommandName = "Command1.";
                      else
                          CommandName = "Command2.";
                      //Retrieve the bounds of the array containing the selected files and folders
                      int index = 0;
                      int last = 0;
                      index = Information.LBound(ppoData);
                      last = Information.UBound(ppoData);
                      string StrID = null;
                      //Create a message showing the names and IDs of all selected files and folders
                      string message = null;
                      message = "Sie haben diese Dateien zum löschen selektiert: " + Constants.vbLf;
                      while (index <= last)
                          if (((EdmCmdData)ppoData.GetValue(index)).mlObjectID1 == 0)
                              message = message + "Folder: (ID=";
                              StrID = ((EdmCmdData)ppoData.GetValue(index)).mlObjectID2.ToString();
                              message = message + StrID + ") ";
                          else
                              message = message + "File: (ID=";
                              StrID = ((EdmCmdData)ppoData.GetValue(index)).mlObjectID1.ToString();
                          message = message + ((EdmCmdData)ppoData.GetValue(index)).mbsStrData1 + Constants.vbLf;
                          index = index + 1;
                      //Display the message
                      EdmVault5 v = default(EdmVault5);
                      v = (EdmVault5)poCmd.mpoVault;
                      v.MsgBox(poCmd.mlParentWnd, message, EdmMBoxType.EdmMbt_OKOnly, CommandName);
      How can I change/add the code to delete the selected files in the folder?
      Any help would be appreciated
      Cheers Mario
