Recorded Print Macro Prints Incorrectly
Question asked by Eddie Pellegrin on May 24, 2016
Latest reply on May 24, 2016 by Eddie Pellegrin
I have recorded a macro simply printing the active document. The problem I'm having is that if the drawing has (for example, 4 sheets) it will print each sheet 4 times. This only seems to happen when using #TASK. Is it because #TASK runs the macro on each sheet? Or is something wrong with the way I am doing it? Any info would be greatly appreciated. Thanks in advance.
_____________________________________________
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Part.PrintDirect
