Create your drawing from your model as normal
Click on the view that you wish to show your Geometric dimensions
(that are on your model)
Click Property manager
Click on DimXpert annotations in Import Options and hey Presto.
A bit crude but the can be individually removed, repositioned or
edited.
This is long delayed, but thanks for that explanation. It seems if
you use a different method of inserting model views, you cannot get
the DimXpert dims onto the drawing. I use predefined views on
templates, where there seem to be no options. Anyway, you can put
them on if you use Insert, View, Model, or if you use the View
Palette.
Click on the view that you wish to show your Geometric dimensions (that are on your model)
A bit crude but the can be individually removed, repositioned or edited.
This is long delayed, but thanks for that explanation. It seems if you use a different method of inserting model views, you cannot get the DimXpert dims onto the drawing. I use predefined views on templates, where there seem to be no options. Anyway, you can put them on if you use Insert, View, Model, or if you use the View Palette.
Thanks again.
