ADA. D.24/05/2016
Dear all,
I'm trying to make a macro which fills in a cell in a specific excel workbook. I've got this working, but the only thing i would still like to do is to close the workbook again after pressing the ok button (or any other event, doesn't really matter for the question).
I've tried to accomplish this through the XLbook.close command (XLbook is dim'd as Excel.Workbook in this case), but it's giving me the following error: Object variable or With block variable not set (Error 91)
I can't really find out what's the problem in here, it's probably something stupidly easily, but i can't seem to find it?
I'll hope you guys can help me find the error in this code. The code is as following:
    Dim xlApp As Excel.Application
    Dim XLbook As Excel.Workbook
Private Sub CommandButton1_Click()
    MsgBox TextBox1.Value
    xlApp.ActiveSheet.Range("C3").Value = TextBox1.Value
Private Sub CommandButton2_Click()
    Set xlApp = CreateObject("Excel.Application")
    'Set XLbook = xlApp.Workbook("X:\Arno\Parametrisch model\Test.probeersels\Excel file vullen vanuit Solidworks\Excelfile.xlsx")
    'xlApp.Workbooks.Close FileName:="X:\Arno\Parametrisch model\Test.probeersels\Excel file vullen vanuit Solidworks\Excelfile.xlsx"
    XLbook.Close (SaveChanges = False)
    Unload Me
Private Sub UserForm_Initialize()
    'Dim xlApp As Excel.Application
    'Dim Sourcebook As Excel.Workbook
    xlApp.Visible = True
    Set XLbook = xlApp.Workbooks.Open("X:\Arno\Parametrisch model\Test.probeersels\Excel file vullen vanuit Solidworks\Excelfile.xlsx", , False) 'Opens Workbook with your instance of xlBook Object
    'xlApp.Workbooks.Open FileName:="X:\Arno\Parametrisch model\Test.probeersels\Excel file vullen vanuit Solidworks\Excelfile.xlsx"
    'xlApp.ActiveSheet.Range("C3") = TextBox1.Value
The code is written in VBA.
Thank you for your help,
Best regards,
Arno
