Hi all,
My first attempt at any macro API stuff. I have plagiarized most of this from other posts, and have made it work for the most part. I am stuck on 2 issues: 1) I would like to to change the custom property of both assemblies (.sldasm) & parts (.sldprt). 2) perform the function not just the folder that I specify, but any subfolders as well. (#TASK is not the answer I am looking for).
Any help is appreciated.
Dim swCustMgr As SldWorks.CustomPropertyManager
Dim fileerror As Long
Dim filewarning As Long
Dim vCustNames As Variant
Dim vCustTypes As Variant
Dim vCustVals As Variant
Dim PN As String
Dim OverwriteExisting As Integer
Dim VAL As Integer
Dim files As Variant
Const folder As String = "C:\Users\Radair.QUALITY\Documents\_RAdair Design\Purchased\Advantech\"
files = Dir(folder & "*.sldprt", vbNormal)
Do While files <> ""
swApp.OpenDoc6 folder & files, swDocPART, 0, "", fileerror, filewarning
files = Dir
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then Exit Sub
'Activate Custom Prop Manager
Set swCustMgr = swModel.Extension.CustomPropertyManager("")
'Add the new property you want for this is the PartNum
VAL = swCustMgr.Add3("PartNum", swCustomInfoType_e.swCustomInfoText, "", OverwriteExisting)
'Now the FOR command will search and find the property you want to delete but first it will store its value under the PN
'then it will delete the property PartNo
'Next step will enter the stored value from the deleted property to the new one
swCustMgr.GetAll vCustNames, vCustTypes, vCustVals
For i = 0 To UBound(vCustNames)
If vCustNames(i) = "PartNo" Then PN = (vCustVals(i))
If vCustNames(i) = "PartNo" Then swCustMgr.Delete (vCustNames(i))
If vCustNames(i) = "PartNum" Then vCustVals(i) = PN
VAL = swCustMgr.Set2("PartNum", PN)
Next
swModel.Save
swApp.CloseDoc swModel.GetTitle()
Loop
