0 Replies Latest reply on May 23, 2016 10:38 AM by Samantha Szkirpan
    change feature name using selectedfeatureproperties method
    Samantha Szkirpan
      I'm using a VBA macro to change the name of linear pattern features in Solidworks
      when using the selectedfeatureproperties command, I'm running into an issue. The command will execute properly when given an exact string value for the name, but will not execute properly when given a predetermined variable for the name. Examples being:
      boolstatus = part.selectedfeatureproperties(0, 0, 0, 0, 0, 0, 0, 1, 0, "Jingles")
      WILL rename the selected pattern to Jingles, but
      Dim PartName as string
      PartName = "Jingles"
      boolstatus = part.selectedfeatureproperties(0, 0, 0, 0, 0, 0, 0, 1, 0, PartName)
      WILL NOT rename the selected pattern at all, and after the variable PartName has been declared
      boolstatus = part.selectedfeatureproperties(0, 0, 0, 0, 0, 0, 0, 1, 0, " " & PartName)
      WILL rename the selected pattern to  Jingles(with the added space in front of the word), but
      boolstatus = part.selectedfeatureproperties(0, 0, 0, 0, 0, 0, 0, 1, 0, "" & PartName)
      To an extent the added space in front of the part name won't matter at first, but it may become a problem later when others are using this assembly file to search for parts which is why I would prefer to find a way to rename the pattern without needing that extra space.
      Any help would be great, thanks.
