2 Replies Latest reply on May 21, 2016 3:39 PM by Jonathan Halderman
    2015 Smart Dimension in Sketch Defaults to Dimension ID Entry
    Jonathan Halderman
      When creating a sketch for a new part, I often need to dimension the sketch to define the size of the geometry.
      In prior versions of solidworks, the workflow for adding these sketh dimensions was:
      1. Click on the Smart Dimension button
      2. Select item 1 as a dimension endpoint
      3. Select item 2 as an endpoint
      4. Click the location where the dimension should reside
      5. Enter the value of the dimension
      6. Click the green check to confirm
      After I installed 2015 Solidworks SP 5.0, when I complete step 4 above, the following dialog appears:
      The dimension ID is always the default box that is highlighted and I have to hit the TAB key to get to the box for entering the actual dimension value.
      This is a massive time sink.  Mostly because this is the only installation of SolidWorks I use that has this glitch and I often forget that I need to do this stupid workaround.
      Where/how do I tell SolidWorks that the default highlighted entry box should be the dimension itself and not the dimension ID?
      Thank you,
      Jonathan
