7 Replies Latest reply on May 27, 2016 2:14 PM by Deepak Gupta
    API for adding equation to line
    Lasse Nielsen
      Hi there,
      I have 3 construction lines
      Line 1: D1@sketch1 is 17mm
      Line 2: D2@sketch1 is 180mm
      Line 3: I need this line to be equal to Line2/Line1 using a macro
      Apparently the following macro doesn't do the job.
      swEquationMgr.Add -1, """D3@Sketch1""=""D2@Sketch1""/""D1@Skech1"""
      What am I doing wrong? Please help.
        • Re: API for adding equation to line
          Deepak Gupta
          Use these codes
          Option Explicit
              Dim SwApp           As SldWorks.SldWorks
              Dim Part            As SldWorks.ModelDoc2
              Set SwApp = Application.SldWorks
              Set Part = SwApp.ActiveDoc
              Part.GetEquationMgr.Add3 0, """D3@Sketch1"" = ""D2@Sketch1""/""D1@Sketch1""", True, swThisConfiguration, Empty
          'Replace  swThisConfiguration with swALLConfiguration if you need it for all configurations
              Lasse Nielsen
              This is my code so far.
              Option Explicit
              Dim swmodel As SldWorks.ModelDoc2
              Dim swSketchMgr As SldWorks.SketchManager
              Dim swsketchSeg As SldWorks.SketchSegment
              Dim swEquationMgr As SldWorks.EquationMgr
              Dim intSDR As Integer
              Dim intDiameter As Integer
              Dim dblSDR As Double
              Dim dblDiamter As Double
              Dim dblRadius As Double
                  Set swmodel = swApp.ActiveDoc
                  Set swSketchMgr = swmodel.SketchManager
                  Set swEquationMgr = swmodel.GetEquationMgr
                  'Turn off "input dimension value"
                  swApp.SetUserPreferenceToggle swInputDimValOnCreate, False
                  'Select plane and insert sketch
                 swmodel.Extension.SelectByID2 "XY Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0
                 swSketchMgr.InsertSketch True
                  'turn on direct addition to database
                  swSketchMgr.AddToDB = True
                  intSDR = 17
                  intDiameter = 180
                  dblDiamter = intDiameter / 1000
                  dblRadius = dblDiamter / 2
                  dblSDR = dblDiamter / intSDR
                  'Create construction lines
                  Set swsketchSeg = swSketchMgr.CreateCenterLine(0, 0, 0, intSDR / 1000, 0, 0)
                  swsketchSeg.Color = 16711935
                  swmodel.SketchAddConstraints "sgHORIZONTAL2D"
                  swmodel.AddHorizontalDimension2 dblSDR / 2, -0.005, 0
                      'Coincident to origin
                      swmodel.Extension.SelectByID2 "", "EXTSKETCHPOINT", 0, 0, 0, False, 0, Nothing, 0
                      swmodel.Extension.SelectByID2 "", "SKETCHPOINT", 0, 0, 0, True, 0, Nothing, 0
                      swmodel.SketchAddConstraints "sgCOINCIDENT"
                  Set swsketchSeg = swSketchMgr.CreateCenterLine(0, 0, 0, 0, dblRadius - dblSDR, 0)
                  swmodel.SketchAddConstraints "sgVERTICAL2D"
                  Set swsketchSeg = swSketchMgr.CreateCenterLine(0, dblRadius - dblSDR, 0, 0, dblRadius, 0)
                  'Outer tube diameter
                  swSketchMgr.CreateCircle 0, 0, 0, 0, dblRadius, 0
                      'Coincident to construction lines
                      swmodel.Extension.SelectByID2 "", "SKETCHPOINT", 0, dblRadius, 0, False, 0, Nothing, 0
                      swmodel.Extension.SelectByID2 "", "SKETCHSEGMENT", 0, dblRadius, 0, True, 0, Nothing, 0
                      'Adding dimension
                      swmodel.ClearSelection2 True
                      swmodel.AddDimension2 dblRadius * -1, dblRadius * -1, 0
                  'Inner tube diameter
                  swSketchMgr.CreateCircle 0, 0, 0, 0, dblRadius - dblSDR, 0
                      swmodel.Extension.SelectByID2 "", "SKETCHPOINT", 0, dblRadius - dblSDR, 0, False, 0, Nothing, 0
                      swmodel.Extension.SelectByID2 "", "SKETCHSEGMENT", 0, dblRadius - dblSDR, 0, True, 0, Nothing, 0
                      'Adding dimension
                      swmodel.Extension.SelectByID2 "", "SKETCHSEGMENT", 0, (2 * dblRadius - dblSDR) / 2, 0, False, 0, Nothing, 0
                      swmodel.AddDimension2 dblRadius * -1, (2 * dblRadius - dblSDR) / 2, 0
                  swEquationMgr.Add3 0, """D3@Sketch1"" = ""D2@Sketch1""/""D1@Sketch1""", True, swAllConfiguration, Empty
              But the equation is not added to the third line when i run the code. What am I doing wrong? :S
