So I am in SW16 and in a drawing.
I box select a bunch of lines... say 380.
I RMB to select Make Block or Move Entities... but the menu does not show up!
Now what? I never experienced this in SW15.
Hey Sarah,
What SP are you on,? I am on SP3 and have this dropdown after selecting a mess of lines and rmb
Brian
Same, SP3...
Did you expand this dialog box??
You can customize the dialog box....
The problem is that I don't even get that menu!
I have the menu most of the time... but sometimes it just doesn't show up when I right click!
here is an example.
I select one chain with my RMB, then CTRL+RMB.... to get no menu!
How do I select the second chain without my RMB menu?!?
Okay, so it is working sporadically now!
I was able to successfully RMB until I tried to do it a sixth time!
Two RMB for each step and the last one won't work.... WHY!????
And this is not native to my machine. A coworker also on SW16 SP3 is having the same issue.
Any ideas why?
have you tried to run a repair on the installation? Also, if possible, log in as a different user on your workstation to see if that user has the same issue
Hey Sarah,
Brian
