4 Replies Latest reply on May 19, 2016 6:45 PM by Chris B.
    Mirrored components (in Assembly) do not change configuration with the original component
    Chris B.
      Hi All,
      I thought if I mirrored the right hand component, whenever I change it's configuration the mirrored one should also change to that new configuration.
      Is there a way to make it do that?
      Without design tables?
      I can do it with a design table, but the second component does not change its configuration until you open and close the design table.  This is not an elegant solution - I'm sure someone will miss that crucial step, and there will be the wrong config on one side.
