So, I've moved from Hydraulics to electrical systems, and am encountering some new challenges. I've managed to work through most of it but I've got a bit of an annoyance...
Since wire numbers are critical, we use 90% manual wire numbering, and the Wire Tag variable does exactly what we need it to do - place the wire number on the symbol near the connection point to which the wire is attached.
That's great, exactly what I want, and everyone is happy.
Until I use the automatic numbering tool to add the last few wire numbers ------ it then places wire numbers approximately 1/8" away from the already existing, perfect, exactly what I want wire numbers...
As you can see, the added numbers are redundant.
How do I remove the wire marks so that only the tags are used?
I'll be honest - I thought this was a simple question and would be answered right away. It seems like this is pretty much common sense - show the number or not. But after 90 minutes of searching I have nothing. Can't find the menu option anywhere, starting to doubt whether this common sense feature even exists.
BUT I DID FIND A LAZY, HALF-A** SOLUTION.
Project > Configurations > Font
Under "Wire Number" in the bottom section, change text height to 0.0000000000000001.
This will effectively hide the numbers.
If anyone out there has a real solution that doesn't feel like duct tape, I'm all ears.
