- Sheet Metal.SLDPRT.zip875.8 KB
No one else has this question
You are right.This would have to be made in a separate operation. However, SolidWorks still shows the warning that I have attached. I have tried numerous options to see if this gusset feature continues to post this particular warning. After two hours worth of attempts, I am no closer to discovering the reason for this warning than I was when I first started. I thought that the feature failed due to giving the gusset thickness a different value than the default metal gage and that the inside and outside radii of the feature caused a thinner area than the default metal gauge. This seems to have no effect in this particular case. This example is pulled directly from "SOLIDWORKS 2016 Learn by doing - Part 1". After tr
How would the shop create that? The only thing I can think of is to use a die to press that gusset into the formed part, and then I would be very doubtful it could be done.
I could be wrong and often am....but that doesn't look like something that would be normal to me.
