retrieving the part component names of all drawing views in a multi sheet drawing
Question asked by John Smith on May 14, 2016
Latest reply on May 15, 2016 by Deepak Gupta
I have the following code to retrieve the part component names of all drawing views in a multi sheet drawing. it works fine for views containing assemblies only but when it comes to views of part components it returns NULL for the array "vDrawChildCompArr", your help is appreciated, thanks.
Dim sheetCount As Long
    Dim viewCount As Long
    Dim currentSheetNum  As Integer
    currentSheetNum = 0
    Dim ss As Variant
    ss = swDraw.GetViews                                              'The return value is an array of arrays with a length equal to the number of sheets in the drawing document.
    For sheetCount = LBound(ss) To UBound(ss)           'goes through all sheets
        currentSheetNum = currentSheetNum + 1
        Dim vv As Variant                                                    'defines a variable to explore through the views of each sheet
        vv = ss(sheetCount)                                                'gets views of each sheet
        For viewCount = 1 To UBound(vv)                          'first element of the array is the sheet itself and we dont need it
            Debug.Print currentSheetNum
            Set swView = vv(viewCount)
            Set swRootDrawComp = swView.RootDrawingComponent
            vDrawChildCompArr = swRootDrawComp.GetChildren
                    For Each vDrawChildComp In vDrawChildCompArr
                        Set swDrawComp = vDrawChildComp
                        Set swComp = swDrawComp.Component
                        strName = swComp.Name2
                        Debug.Print (strName)
                    Next vDrawChildComp
           Next viewCount
    Next sheetCount
