can check font of text in balloon, and then correct them. would like them all the balloons to be the same size.
if design checker can not is there an easy way to select all the balloon and apply the same property to them?
Bruce
Bruce
Bruce,
Look at the Document Checks -> Balloon Font and you should be able to set the standard there. Then use Auto Correct to have all the errors corrected.
Hope that helps
Aaron
