I cant figure out how to cut this using loft to match the flatness of the plate? or any feature? Any short cuts? I created a outline of the face on the far right.
Welcome to the forum. Maybe I'm just slower than usual today, but I'm afraid I don't understand what you're trying to do. I don't see an "outline of the face on the far right". Can you post the Part model, maybe with a little more explanation of what you're trying to do? (Click on the text "Use advanced editor" at top right of the Reply box, then there will be a link at lower right to attach files.)
I am trying to remove that highlighted part in blue. Not sure if there is a way. Basically that black face has a closed sketch. But not sure how I can guide it to just remove it.
Easy-peasy. Use the move face command. Post the file and I will do it for you.
