I have a simple assembly, with multiple patterns. The various configs represent these patterns. Basically each configuration has a different connector and calls the various connectors with the various patterns to fit in the holder.
I've tried to copy some of the configs as some are very similar, but for some reason if I copy multiple, they all take the properties of 1 of the original configs. For example, I have 10 configs that are similar, So i copy the 10, but the 10 new ones have all the patterns unsuppressed. The other properties seem to follow properly.
The various patterns are under folders according to the type of connector. Could the folders be causing the issue?
I would Pack & Go assembly to new folder instead of copy and then modify it the way I need.
