Is there a "semi automated" way to create tubing and hose runs?
Say I have tube fitting A, and tube fitting B (which is not co-planar to A, making the routing more difficult) and want to connect them with a piece of tubing. How would I best go about this?
I have done this in the past with 3D sketches and sweeps, however it always seemed to require a lot of tweaking and depending on how awkwardly the tube fittings were positioned relative to each other, the results weren't always perfect.
Thanks for any help.
Have you tried SOLIDWORKS Routing module?
