I clicked something accidentally and I lost my entire workspace and setup. I decided to reset entire SoildWorks to factory setup (workspace and system options). As a result of this action I lost color of dimensions in my drawings. When SW is opening a drawing it flashes green dimension for a fraction of a second and turns them
black. Toggling the “Display Mode” doesn’t help because SW moves dimensions from “dim” layer to “Format” layer. The drawings I am opening still maintain the
setup of my customized template. In “Document roperties” all types of dimensions are shown on the “dim” (green) layer. I tried to make a simple test part and made
the corresponding drawing. I noticed hat unless I switch layers to “dim” the dimension manager generates black imensions. Before the accident, the etup in “Document Properties” was sufficient to generate dimensions on the ”dim” ayer. Please help!!!
Is the active Layer set to "Per Standard"? Unless it is, the active Layer will over-ride the settings at Document Properties.
