Hi, I made a standard template drawing for my company with Custom Property links created with Property Tab Builder.
But I cant load that in to the drawing. When i will add the place where I saved the different ones I can´t add, that button is gray and I have try all kind off things to get it work.
I made one that worked on my computer but when all other in company want to use the drawing template it do sent work.
I have also try to but my created custom properties in the folder that is blue but nothing shows when I should pick one from list.
Please help
It points to the Folder not File, If you have the file in your specified folder then it should be ok
