If I put a decal on a casting, is it possible to make it show up in the machining if the machining is a derived part of the casting? Using SW2015 x64, SP4.0.
I have not tried it but I would expect it to work correctly. The only problem could be if the machining operation modified the area containing the decal.
I would also make a suggestion regarding decals. In tools/options/Document Properties/Model Display I suggest turning on "Store appearance, decal...". This will assure that your decal info does not get lost if the file path changes in the future.
