I been learning working with Composer (2014 version) and I got a problem regarding Authors display in Technical illustration detail view.
When I am trying to create vector detail view for my assembly, it creates detailed view of model but doesn't display Author. So far I tried using normal 2D text and dimension Authors and both times they weren't copied into detail view. Sometimes I manage to somehow make it show up, but most of the time I have problem with it.
I tried switching off and on again detail view, reopen Composer but it still happens.
My question would be, is there a setting or a way to control this feature so it displays Authors in vectored detail view whenever I want to?
So far it seemed to happen only in Technical illustration detail view.
If I create normal (not detail) Technical illustration, Author is being displayed just fine.
OK, pretty sure I figured out your problem. Look at the view I attached below. The issue at least in this case is what you are dimensioning and its placement. At the head on detail in green the dimension wont be seen since its not in that area. If you rotate your model and create another detail as you can see in the example below the dimension is visible now. So make sure your dimension is in an orientation and place that will be seen in a detail view before creating said detail view. See if this helps you some on dimensions. For author labels I have never had an orientation issue so if you have a file having trouble with these you could attach that as well. I hope this helps some.
