Is it possible to rename a project?
That only seems to copy the the latest versions, can I copy all versions?Kenneth Barrentine wrote:
no.
create a new project.
move documents from a project to the new project.
delete the empty project.
Thanks. I was trying thru the vault admin using copy project, this did not work. What I did was create a new project with the correct name, then moved everything into the new project and deleted the old project.Kenneth Barrentine wrote:
you are using pdmw's functions to do this correct?
nothing is copied, rather the documents are moved from one project to another.
all the versions are there.
don't be fooled by what you see in windows, if that's in fact what you're referring to.
Could anyone please be more specific about how to do just that?Kenneth Barrentine wrote:
