Hi guys.
I hope someone can give me some advice.
For some reason i can't seem to fix this issue.
I need to solve this or start the assembly over.
I had an existing bracket but had to copy tree the item
to create a new one, without loosing the existing one, as this was a once off item.
I only realized my dilemma once i had to start making drawings. "after i thought i had fixed the issue"
i can reference it to planes as you can see but i think its the world plans that went crooked on me.
-tried to delete the planes not luck
-tried to edit the planes for alignment no luck
1 the only other thing i can think of doing is to delete all the mates in the assembly and start over with the mating process.
Any advice will be helpful.
Kind regards
Luigi Zaca
Could you attach the file to look at? Also you can use the print screen button or snipping tool to capture a picture and paste directly while replying. This would save time and file size would be less.
