I want to configure Hole Wizard for ANSI Inch Tapered Threads to match our company standards. I went to System Options>Toolbox/Hole Wizard>Configure and found the appropriate table (see attached). I successfully added the pitch to each call-out which now works great. But not sure about the other fields, when I use defaults settings and put the NPT's into a block, the result (see attached) is much different than than the Table. I want to permanently change the tap drill depth, the countersink diameter and the tap drill tip angle.
