Check if file is "in use" during Macro save
Question asked by jason kooken on May 5, 2016
Latest reply on Oct 3, 2016 by jason kooken
A am trying to Add warnings to my saving Macro
My new requirements are as follows:
1. I need a message box to alert user that one or both of the files to be saved are in use(locked)
2. I need to give the option to either retry or cancel from that message
Thanks in advance for any help.
below is the working code I have to this point:
    Set Part = swApp.ActiveDoc
    Set swModel = swApp.ActiveDoc
    Set SelMgr = Part.SelectionManager
    Dim proj As String
    Dim dwg As String
    Dim filename As String
    Dim saveLoc As String
    Dim rev As String
    Dim trueRev As String
    Set swCusPropMgr = swModel.Extension.CustomPropertyManager("")
    filename = swModel.GetPathName
    If filename = "" Then
        MsgBox "Please save the file first and try again", vbCritical
        End
'Get Revision
    retval = swCusPropMgr.Get3("Revision", False, rev, trueRev)
    If rev = "-" Then
        rev = ""
    dwg = Strings.Left(filename, Len(filename) - 7)
    proj = Strings.Left(dwg, 4)
'Filepath
        dwg = Strings.Right(dwg, 8)
        Part.Extension.SaveAs "\\xxxxxxx\DWGS\" + proj + "\" + dwg + rev + ".PDF", 0, 0, Nothing, longstatus, longwarnings
        Part.Extension.SaveAs "\\xxxxxxx\DWGS\" + proj + "\" + dwg + rev + ".EDRW", 0, 0, Nothing, longstatus, longwarnings
Message was edited by: jason kooken
