Hi!
I am looking for a way to split the top surface of any solid into (nearly) equal areas, like using wrapped grid lines. A grid line sketch can not be wrapped onto the surface using the 'wrap' feature because the surface is not an extruded one. The 'split' feature can not be used because in that case, the grids will be projected, not wrapped, creating highly dissimilar areas. Any workaround?
Thanks.
