I have a part and during a multi radius fillet the part went transpart when finished. I did the following
part is not set to wire frame
its not set to transparent mode
I removed all apparences
I can't figure out what to do next,
Right click on the Fillet feature and see if you have the transparency icon clicked. If you it could be your graphics card...
I'll try that, but I suspect it may be th egraphics card
Frank,
Try using the rollback bar above the fillet & see if it returns?
You also seem to have another feature after the fillet so I assume the fillet was OK at some point or you couldn't do the following feature?
Has the extrude cut taken out your hole model?
Thanks Kevin, I did the roll back all the way to the beginning and it didn't resolve the issue. I suspect is the graphics card
Make sure that this setting is on:
Most likely that fillet should have failed.
Attach the file to check. And if you're able to find the issue then uncheck the option suggested by Alin as this would increase the rebuild time on each file.
