I am trying to customize the hole wizard so I can set up a standard for our engineering room the way we had it customized in Autocad.
I am trying to:
- Generate the hole in a block (using hole wizard or another feature) very simple from a menu of some sort
- We have 19 categories with 11 sizes for the English version.
- When generating the hole chart the text should cover all of the stated parameters that we establish when generating the hole.
Any ideas if that is possible?
Here is the example on how we did it in AutoCad:
Mateusz,
I believe you want to modify your callout format file. Located in Options>File Locations>Hole Callout Format File. Save a copy before you do, because yours is probably pointing to the initial install location on your C: drive.
Going to have to correlate hole wizard to callout format file verbage to update to out show your notes.
