Hello Everyone,
I have a model part that has been supplied from a manufacturer, although it is made up of 1356 surfaces bodies. As a result the model file size is 22mb. I am trying to reduce the file size of the part so the assembly it is in, is more manageable. Is there a quick and easy way to combine all the surfaces in 1 go and make the file size considerably less? I have tried the Intersect feature to no avail. Any help would be appreciated
Cheers Sam
Hi Sam,
The Knit Surface command would be the next best thing to try.
However having a look at the geometry from your attached image I would say doing it all in 1 go might prove problematic, it'd be worth trying to knit the surfaces into more suitable sizes before doing them all as one.
Regards
Fin
