Somehow my tile note change from DETAIL C SCALE 2:1 TO C (2:1)
try going to options> document properties> views> detail and check the settings you have for the labels, chances are a template or drafting standard you have used has changed this from the detault. and you might need to just tick the 'per standard' checkbox to restore it back to the drafting standard you are intending to use.
Hope this helps
For new details:
Make sure these settings are correct for each view type (Tools>Options):
To reset existing views or add them back in if they get deleted...I'm not sure, hopefully someone else can answer that, because I'd like to know too. BTW, I believe that the above settings were added in SW 2014.
