Hello gents,
I need your help for an analysis. In fact, I would like check if during weld it is possible to keep bearing temperature under 100°c but I have some difficult. Please find below my assembly. The part in grey is the centre of my bearing. I would like weld all my yellow parts. Axle size is 45mm OD and sheet metal thickness is 30mm.
I can't create weld because i have this message "edge weld connector should belong to faces or surface bodies or sheet metal bodies". Can you help me ?
All your parts are solidbodies. If you dont want to know "how much stress the on weld" , use combine features for welding parts.
İf not , you have to create some surface elements for welding features
