Pack and go call selecting too many documents
Question asked by Mark Treadwell on May 2, 2016
I have a macro set up to export all the files we archive when we release a drawing revision - .PDF, .DXF and Pack and Go to .ZIP. Today I noticed it taking a very long time to run on a drawing that isn't particularly large (33 unique parts), and when it was finished I had a 1.6GB zip file which included the top level assembly, 2 levels above the one shown in the drawing. Checking the file references and viewing the Pack and Go dialog "by hand" didn't show me any of the rogue models. We have plenty of carelessly built models with external references that would create this situation, but this doesn't seem to be one of them based on what I see in the Pack and Go window.
What would cause a Pack and Go through the API to come up with a different set of files than what I see when I generate it myself? There aren't any (documented) switches in the 'GetPackandGo' command so I'm not sure how this would be happening.
Here's my code, in case someone can point out an obvious error there:
Option Explicit
Dim swDoc As SldWorks.ModelDoc2
Dim swDocExt As SldWorks.ModelDocExtension
Dim swPackAndGo As SldWorks.PackAndGo
Dim swPageSetup As SldWorks.PageSetup
Dim swDocPrinter As String
Dim Errors As Long
Dim Warnings As Long
Dim Status As Boolean
Dim Statuses As Variant
Dim DestPath As String
Dim FileTyp As Integer
Dim DestFolder As String
Dim FileName As String
Dim CurrentRev As String
' SolidWorks constants
Global Const swDocPART = 1
Global Const swDocASSEMBLY = 2
Global Const swDocDRAWING = 3
Set swDoc = swApp.ActiveDoc
Set swDocExt = swDoc.Extension
Set swPageSetup = swDoc.PageSetup
DestPath = "H:\Drawings for Release\"
If Dir(DestPath, vbDirectory) = "" Then MkDir (DestPath)
  If swDoc Is Nothing Then                                 ' Is doc loaded
    MsgBox ("No document open.")                           ' Need a doc loaded
    End
  Else                                                        ' Doc loaded?
    FileTyp = swDoc.GetType                                ' Get doc type
    If FileTyp = swDocASSEMBLY Or FileTyp = swDocPART Then    ' Model ?
        MsgBox ("Open file is not a drawing.")                ' Reject
        End
    ElseIf FileTyp = swDocDRAWING Then                        ' Drawing ?
        FileName = Left(swDoc.GetTitle, 4)
        If Left(FileName, 2) = "FX" Then FileName = Left(swDoc.GetTitle, 6)
        CurrentRev = swDoc.CustomInfo("Revision")
        FileName = FileName & "REV" & CurrentRev
        swDoc.SaveAs4 DestPath & FileName & ".pdf", 0, 1, Errors, Warnings        ' Create PDF
        swDoc.SaveAs4 DestPath & FileName & ".dxf", 0, 1, Errors, Warnings        ' Create DXF
        Set swPackAndGo = swDocExt.GetPackAndGo
        Status = swPackAndGo.SetSaveToName(True, DestPath & FileName & ".zip")    'Set ZIP save name
        If Len(Dir$(DestPath & FileName & ".zip")) > 0 Then Kill (DestPath & FileName & ".zip") 'Delete existing .zip so they aren't combined.
        Statuses = swDocExt.SavePackAndGo(swPackAndGo)                            'Create ZIP
        'If MsgBox("Print drawing?", vbYesNo, "Export Complete") = vbYes Then    'Print drawing
            'swPageSetup.Orientation = 2 'Landscape
            'swPageSetup.PrinterPaperSize = 17 '11x17 (for HP5200)
            'swPageSetup.ScaleToFit = True
            'swDoc.Printer = "\\ALPHA\HP 5200 PCL_CAD"
            'swDoc.PrintDirect
            'swDocExt.PrintOut2 0, 1, True, "HP 5200 PCL_CAD", ""
            'swDocExt.PrintOut3 0, 1, True, "\\ALPHA\HP 5200 PCL_CAD", "", True  'All sheets, one copy, high quality
        'End If
    Else                                                      ' Else doc type
      MsgBox "Active file is not a SolidWorks document.", vbExclamation
    End If                                                    ' End doc type
  End If                                                      ' End doc load
