Dispatch copy from file card drop down
Question asked by John Power on May 1, 2016
Hi guys, just wondering if anyone knew the functionality behind using the Dispatch Add-In to copy files based off of a drop down selection in a data card...
For example I select Control Box (below) then select a pre-defined Control Box Template in my library I want to create in the next drop down menu, then it creates a new project folder using a template and copies those files into the new project folder.
Is it possible to grab the select files using the Dispatch Copy add-in? I know with templates you can select which files you want to place in but I can't get it to select certain files based off of the drop down menu.
Any thoughts or ideas would be much appreciated, thanks!
