i Can't able to select the plane of a part  for matting
Question asked by Suresh Vijayan on May 2, 2016
Latest reply on May 5, 2016 by Suresh Vijayan
Hi All,
I  cant able to select the plane using selectBYID2  for mating,Used code is below Kindly help me to solve this problem
        Dim TemplateName As String = "C:\Documents and Settings\All Users\Application Data\SolidWorks\SolidWorks 2012\templates\Assembly.asmdot"
        Dim swAssy As AssemblyDoc
        Dim ShaftFilePath As String = "C:\Documents and Settings\3dcad0723\Desktop\New Folder\EditedShaft.SLDPRT"
        Dim CouplingFilePath As String = "C:\Documents and Settings\3dcad0723\Desktop\New Folder\EditedCoupling.SLDPRT"
        'Dim DocExt As ModelDocExtension
        'Opening the parts Before Assembly
        SwApp.OpenDoc6(ShaftFilePath, 1, 0, "", iErrors, iWarnings)
        SwApp.OpenDoc6(CouplingFilePath, 1, 0, "", iErrors, iWarnings)
        'Opening the New Assembly
        swModel = SwApp.NewDocument(TemplateName, 0, 0, 0)
        swAssy = SwApp.ActiveDoc
        'Adding Component (Shaft part)
        swAssy.AddComponent(ShaftFilePath, 0, 0, 0)
        'Adding Component (Coupling Part) Three Times
        swAssy.AddComponent(CouplingFilePath, 0.2, 0, 0)
        swAssy.AddComponent(CouplingFilePath, 0.5, 0.2, 0)
        swAssy.AddComponent(CouplingFilePath, 0.8, 0.4, 0)
        'Mating Components
        swModel.ClearSelection2(True)
        'Selecting Planes Of all Components
        swModel.Extension.SelectByID2("Plane3@EditedShaft-1@Assem1", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
        swModel.Extension.SelectByID2("Plane2@EditedCoupling-3@Assem1", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
        '.Extension.SelectByID2("Plane3@EditedShaft-1@Assem1", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
        'boolstatus = Part.Extension.SelectByID2("Plane2@EditedCoupling-3@Assem1", "PLANE", 0, 0, 0, True, 0, Nothing, 0)
        'AddMating
        swAssy.AddMate3(0, 0, False, 0, 0, 0, 0, 0, 0, 0, 0, False, iErrors)
Thanks in Advance
SureshKumar
