6 Replies Latest reply on May 2, 2016 10:36 AM by Matt Martens
    Problem updating to Workgroup PDM 2016 - API
    JUAN RAMON Sánchez Tabuenca
      I have been using for a few years a VB program to access Workgroup PDM using its API.
      It starts like this:
          Public Sub main()
              On Error GoTo errorHandler
              Dim fileName, newName, TempFile, extension, Pathedrawings, TextoError As String, punto As Integer
              TextoError = "No puede definir conexión a PDM"
              Dim connection As PDMWorks.PDMWConnection
              fileName = My.Computer.FileSystem.ReadAllText("C:\DRWTMP\NUMPLANO.TXT")
              Pathedrawings = My.Computer.FileSystem.ReadAllText("C:\DRWTMP\RutaEdrawings.TXT")
              TextoError = "No puede crear conexión a PDM"
              connection = CreateObject("PDMWorks.PDMWConnection")
              TextoError = "No puede hacer login a PDM"
              connection.Login("pdmwadmin", "pdmwadmin", "10.0.1.24")
      It is giving me an error when it attemps the connection.Login
      I have checked the user, password and vault address are correct.
      I just installed Workgroup PDM 2016 and it stopped working.
      Any idea of what may be causing the problem?
