In particular the side holes where it's perpendicular to the angled surface. (attached)
The customer doesn't want this made from sheet metal. It's either machined, EDM or waterjet. from a block.
Ernie,
It is possible to machine from a billet of aluminum (less the 5/16 holes). However, the cost greatly depends on the tolerance of the features/dimensions.
The holes can be pierced with a secondary tool (depending on the tolerance required).
A budgetary quote for such a tool, that would pierce one or two holes at a time, is around $14,000.00
We can send you a formal quote if you send us a detailed part print.
Rick
That would be difficult, and expensive, to drill the holes after bending. It's also very long for a drill bit.
You may need a long drill, and drill before the ends are bent.
Or, drill at angles as a flat pattern, then bend.
Another option is make it a cast part.
