Hi all,
I have been adjusting bump map many times on this part today.
Now, the option to edit the bump map values has disappeared.
Please, can anyone tell me how to get back the Bump Map option?
Here is the image. Wood grain bump map is too deep.
Is this 2015 or 2016?
Looks to be there for both of my SW2015 and SW2016 versions (see attached) but then again, there my be some special conditions of your particular file that are preventing all the appearance controls from being enabled?
Mark
Hi Chris,
If you enable PV360 addin, I believe you will see the bump mapping option again.
I guess this is only visible when using PV360..
Regards,
Flemming
Now I am embarassed
I had restarted my PC, and forgot to re add-in Photoview 360.
Once I did that, bump mapping came back.
Problem solved. Thank you very much!
Hi Chris,
Regards,
Flemming
