I am trying to get a small block to travel round a path.
I have a path mate between the box and the spline.
If I set the path constraint to "Free" then I can drag the box around the path with the mouse and there are no problems. I then set the path constraint to "percent along path" and set up an animation motion study. I set two keyframes for the path constraint 0%
and 100%.
I press play and nothing happens. The box does not move.
Is this my problem or a SW bug?
Hi Brad,
You cannot drag component after defining Path mate with percent. This mate blocks all DOFs. You can see message when try to drag component.
To animate this you have to specify Path mate motor.
Just add SW Motion Add-in and Create a Path mate motor, then calculate
Amit
