Inserting a balloon from macro off sheet crashes Solidworks
Question asked by Adam Carder on Apr 28, 2016
Latest reply on Apr 28, 2016 by Deepak Gupta
I have a macro that gets the current revision property and inserts a formatted balloon on the page (EPDM revision control). The problem seems to exist when the user clicks off the sheet and then runs the macro. It cannot properly create the balloon, so Solidworks just crashes. I cannot seem to trap the error if the balloon is null. Is there a reliable way to select something on screen that overrides the user selection? Tried activating the sheet, but I could not get that to work. Using SW 2014 SP5
Dim swApp As Object
Dim myNote As SldWorks.Note
Dim swAnn As SldWorks.Annotation
Dim revisionString As String
Dim boolStatus As Boolean
Set swModel = swApp.ActiveDoc
If (swModel.GetType = swDocumentTypes_e.swDocDRAWING) Then
    'Get revision prop
    revisionString = "A"
    'insert balloon
    Set myNote = swModel.InsertBOMBalloon2(2, 0, 0, revisionString, 0, "")
    If (myNote Is Nothing) Then
        Exit Sub
    'remove leader
    If myNote.IsBomBalloon() Then
        myNote.SetBalloon swBalloonStyle_e.swBS_Triangle, swBalloonFit_e.swBF_Tightest
        Set swAnn = myNote.GetAnnotation
        'boolStatus = swAnn.SetPosition(0, 0, 0)
        swAnn.SetLeader3 swLeaderStyle_e.swNO_LEADER, swLeaderSide_e.swLS_SMART, False, False, False, False
