I'm having some trouble getting this sketch to loft as a bent piece, although it will loft as a formed piece. I just can't seem to figure out what it is I'm doing wrong - and I need the bend lines so we can form this piece correctly on the press brake. Any ideas as to what it is I've done wrong?
Frank,,, I was not able to open your assembly file (parts not included) so not sure what your thickness or direction should be but I managed to get this to work. The main issue is the corresponding lines for the front flange were not parallel. There is a parallel relation on sketch6 but it looks like it is related to some construction geometry on the same sketch. I deleted that relation and added a parallel relation to the corresponding line on sketch1. I did not notice any movement of the line. I also deleted all you sketch radii did a corner trim (sharp intersection) and added the appropriate bend radius in the Loft manager. If I didn't do that I ended up with multiple bends in each bend area.
Edit:.. I added a few more screenshots.
